[Geoserver-devel] [jira] (GEOS-5387) JSON Rest Interface returns empty result for layergroup when containing exact 5 layers with default style
Christopher Dresel created BugGEOS-5387
Issue Type:
BugBug
Affects Versions:
2.2, 2.1.4
Assignee:
Andrea Aime
Components:
REST
Created:
31/Oct/12 2:54 AM
Description:
When using JSON Rest Interface for layergroups which contains exact 5 layers with default styles an empty result is returned.
How to reproduce (with Demodata):
Layergroup spearfish contains 6 layers, which are all configured to use default style.
http:/127.0.0.1/geoserver/rest/layergroups/spearfish.json -> works (6 layers, 6 default styles)
Goto admin interface and remove one layer from layergroup.
http:/127.0.0.1/geoserver/rest/layergroups/spearfish.json -> doesn’t work (5 layers, 5 default styles)
Goto admin interface and uncheck one default style checkbox.
http:/127.0.0.1/geoserver/rest/layergroups/spearfish.json -> works (5 layers, 4 default styles)
Goto admin interface and delete unchecked layers.
http:/127.0.0.1/geoserver/rest/layergroups/spearfish.json -> works (4 layers, 4 default styles)
As you see, the bug only appears when using exact 5 layers with 5 default styles.
Environment:
Windows Server 2008, Apache Tomcat 7 (Service)
Project:
Priority:
MajorMajor
Reporter:
Christopher Dresel
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
