Landry Breuil created GEOS-5388 |
Issue Type: |
Bug |
Affects Versions: |
2.2.1 |
Assignee: |
Components: |
Security |
Created: |
31/Oct/12 8:59 AM |
Description: |
Geoserver 2.2.1 running from the war in a tomcat container. With the default root/admin configuration, default datadir provided by geoserver. When logged in as root or admin if i enable VERBOSE_LOGGING.properties logging type, save, go again to settings page and try to save again, two exceptions are dumped in the log : org.springframework.security.authentication.BadCredentialsException: Bad credentials forroot But i am logged in with correct credentials. If i try to save another setting (say, auth filters), the two exceptions are thrown too, be it with admin or root user. This is a bit confusing. The first exception should be shown only when trying(and failing) to login as root, no ? Or it’s the rememberme cookie which should take precedence over root provider ? |
Environment: |
Debian squeeze, tomcat 6.0.35 |
Project: |
Priority: |
Major |
Reporter: |
