Issue Type:
Bug
Affects Versions:
2.2
Assignee:
Andrea Aime
Created:
01/Nov/12 2:40 PM
Description:
Hi All,
I’m stuggling with an incorrect reprojection between EPSG:23700 and EPSG:4326.
In Geoserver 2.2 the valuable reprojection console cannot correctly reproject between these two CRS. The geoserver-calculated values are:
EPSG:23700 600000 200000
EPSG:4326 -71.19183580066083 -0.5098768030511279
The same reprojection with the gdaltransform tool gives the correct EPSG:4326 values:
600000 200000
18.3882398857909 47.1422215781462
Unfortunately this reprojection error ruins all native EPSG:23700 layers when using them with an EPSG:4326 viewer.
Geoserver 2.1.2 is okay, does not produces this error.
Please tell me about the fix for this because we need Geoserver 2.2 and its fine REST capabilities.
Thank You
Project:
Priority:
Major
Reporter:
Tamás Szálka
If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa).
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
