[Geoserver-devel] [jira] (GEOS-5403) Error importing data from Oracle
Darel Lasrado created BugGEOS-5403
Issue Type:
BugBug
Affects Versions:
2.2
Assignee:
Andrea Aime
Components:
Oracle
Created:
13/Nov/12 5:19 PM
Description:
When I try to import data from Oracle using Data->Import Data, I get the below error.
org.apache.wicket.WicketRuntimeException: Error attaching this container for rendering: [Page class = org.opengeo.data.importer.web.ImportPage, id = 26, version = 0]
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1765)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 47
at org.geoserver.web.wicket.GeoServerTablePanel.selectIndex(GeoServerTablePanel.java:367)
at org.opengeo.data.importer.web.ImportPage.doSelectReady(ImportPage.java:305)
at org.opengeo.data.importer.web.ImportPage$3.populateItem(ImportPage.java:241)
at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:562)
at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:131)
at org.apache.wicket.Component.internalBeforeRender(Component.java:1071)
at org.apache.wicket.Component.beforeRender(Component.java:1105)
at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1753)
… 97 more
Let me know if you need more details
Environment:
DEV
Project:
Priority:
CriticalCritical
Reporter:
Darel Lasrado
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
