[Geoserver-devel] [jira] (GEOS-5404) CannotCropException is raised when requesting a reprojected coverage in WCS 1.1.1
Peter Hopfgartner created BugGEOS-5404
Issue Type:
BugBug
Affects Versions:
2.2.1
Assignee:
Andrea Aime
cannotcropexception.txt, getcoverage_with_default_crs.xml, getcoverage_with_other_crs.xml
Components:
WCS
Created:
14/Nov/12 4:55 AM
Description:
When requesting a coverage in WCS, specifying a CRS differnt from the default one, I get the obove mentioned exception.
I can download the coverge in it’s default projection or, when using WCS 1.0.0, in any projection.
The dataset is the NASA Blue Marble data set in ECW
Environment:
CentOS 5.8, 64 bit, Java™ SE Runtime Environment (build 1.6.0_33-b03)
Project:
Priority:
MajorMajor
Reporter:
Peter Hopfgartner
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
