Issue Type:
Sub-task
Assignee:
Andrea Aime
Created:
16/Nov/12 5:20 AM
Description:
The Mercator1SPGoogle.java file does not include a header, however an educated guess based on package name may indicate this file is from GeoTools (and thus provided under LGPL).
It was used as an example here: LGPL from GeoTools
Update with the following header:
/* Copyright (c) 2004-2012 TOPP - www.openplans.org. All rights reserved.
* (c) 2003-2004 Open Source Geospatial Foundation (LGPL)
* This code is licensed under the GPL 2.0 license, available at the root
* application directory.
Project:
Priority:
Major
Reporter:
Jody Garnett
If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa).
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
