[Geoserver-devel] [jira] (GEOS-5463) Integrated tile cache scalability issue
Andrea Aime created BugGEOS-5463
Issue Type:
BugBug
Affects Versions:
2.2.1
Assignee:
Andrea Aime
Components:
GWC
Created:
16/Nov/12 8:07 AM
Description:
GeoServerTileLayer uses a static canonicalizer to act as the source of the meta-tile locks. This means if 10 metatiles on the same area but different layers get in they will be locking each other out, since the object acting as the synchronization key only uses the geometry, not the layer name.
Simple solution: make the canonicalizer an object field, so that there is one per layer.
Fix Versions:
2.2.2
Project:
Priority:
CriticalCritical
Reporter:
Andrea Aime
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
