[Geoserver-devel] [jira] (GEOS-5468) WMS module contains some GeoTools LGPL headers
Jody Garnett created Sub-taskGEOS-5468
Issue Type:
Sub-taskSub-task
Affects Versions:
2.3-beta1
Assignee:
Andrea Aime
Components:
WMS
Created:
18/Nov/12 12:17 AM
Description:
Review found the following:
  • wms/src/test/java/org/geoserver/wms/decoration/ScaleRatioDecorationTest.java - GeoTools LGPL header
  • wms/src/test/java/org/geoserver/wms/map/quantize/ColorIndexerTest.java - GeoTools LGPL header
  • wms/src/main/java/org/geoserver/wms/map/quantize/ColorIndexerCRIF.java - GeoTools LGPL header
  • wms/src/main/java/org/geoserver/wms/map/quantize/ColorIndexerOpImage.java - GeoTools LGPL header
  • wms/src/main/java/org/geoserver/wms/map/quantize/ColorIndexerDescriptor.java - GeoTools LGPL header
These can be updated with our standard header, keeping the geotools history:
/* Copyright (c) 2012 TOPP - www.openplans.org. All rights reserved.
 *           (c) 2008 Open Source Geospatial Foundation (LGPL)
 * This code is licensed under the GPL 2.0 license, availible at the root
 * application directory.
Project:
Priority:
MajorMajor
Reporter:
Jody Garnett
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
