Issue Type:
Bug
Affects Versions:
2.2.1
Assignee:
Andrea Aime
Components:
Oracle
Created:
23/Nov/12 1:13 AM
Description:
This one is a bit more serious, after configuring a layer as per GEOS-5474, the GetCapabilities for WMS 1.3.0 trips up.
Displaying in the browser results in the error message:
This page contains the following errors:
error on line 4746 at column 17: XML declaration allowed only at the start of the document
Below is a rendering of the page up to the first error.
…snip…
Inspection of the line 4746reveals:
<CRS>EPSG:61346405</CRS>
<CRS>EPSG:61356405</CRS>
<CRS><?xml version="1.0" encoding="UTF-8"?><ServiceExceptionReport version="1.3.0" xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ogc http://localhost:8080/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd"> <ServiceException>
javax.xml.transform.TransformerException: org.geoserver.platform.ServiceException: Error occurred trying to write out metadata for layer: POINT_TEST
Unexpected error obtaining bounding box for layer POINT_TEST
Argument &quot;GDA94&quot; has 3 dimensions, while 2 was expected.
</ServiceException></ServiceExceptionReport>
Environment:
Oracle 11g Express Edition
Project:
Priority:
Major
Reporter:
Jody Garnett
If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa).
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
