Issue Type:
Improvement
Affects Versions:
2.2.2, 2.3-beta1
Assignee:
Andrea Aime
Components:
WPS
Created:
10/Dec/12 9:03 AM
Description:
Request builder doesn’t handle collections as input, only one element could be inserted.
For example:
-Select the ras:RangeLookup process from the request builder dropdown menu;
-Only one element of the parameter “ranges”, that is defined as a List of Range objects, could be inserted.
Environment:
all
Project:
Labels:
wps requestbuilder
Priority:
Minor
Reporter:
Damiano Giampaoli
If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa).
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
