Issue Type:
Bug
Affects Versions:
2.2.2
Assignee:
Justin Deoliveira
Components:
Configuration
Created:
13/Dec/12 8:47 AM
Description:
Per the documentation here (http://docs.geoserver.org/stable/en/user/installation/windows/binary.html), I created
GEOSERVER_DATA_DIR and GEOSERVER_HOME
If GEOSERVER_DATA_DIR points to:
D:\D:\Geoserver_data
It works.
If it points to:
D:\Geoserver_data\ (note the trailing slash)
The start.bat then lists the options for starting java.exe. It doesn’t actually start geoserver. I get something like:
Welcome to GeoServer!
JAVA_HOME: C:\Program Files (x86)\Java\jdk1.6.0_26\
Please wait while loading GeoServer…
Usage: java [-options] class [args…]
(to execute a class)
or java [-options] -jar jarfile [args…]
(to execute a jar file)
where options include:
-client to select the “client” VM
-server to select the “server” VM
-hotspot is a synonym for the “client” VM [deprecated]
The default VM is client.
(and on)
Having a trailing slash shouldn’t cause that to happen.
Environment:
Windows 2008 R2 SP1.
Project:
Priority:
Minor
Reporter:
Jonathan Moules
If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa).
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
