[Geoserver-devel] [jira] (GEOS-5502) GeoServer fails to start if GEOSERVER_DATA_DIR is set
Jonathan Moules created BugGEOS-5502
Issue Type:
BugBug
Affects Versions:
2.2.2
Assignee:
Justin Deoliveira
Components:
Configuration
Created:
13/Dec/12 10:38 AM
Description:
Following from http://jira.codehaus.org/browse/GEOS-5500 - it seems that if I set
GEOSERVER_DATA_DIR to D:\Geoserver_data
Geoserver will fail to start giving me the below error. The documentation doesn’t indicate I need to do anything with the given directory (it has write permissions and Geoserver has written some stuff to it), so maybe I need to do something.
Geoserver works fine if I delete that variable and therefore use the default directory.
Welcome to GeoServer!
JAVA_HOME: C:\Program Files (x86)\Java\jdk1.6.0_26\
Please wait while loading GeoServer…
0 [main] INFO org.mortbay.log - Logging to org.slf4j.impl.SimpleLogger@anonymised.com vi
a org.mortbay.log.Slf4jLog
280 [main] WARN org.mortbay.log - Deprecated configuration used for C:\geoserver
-2.2.2/webapps
312 [main] INFO org.mortbay.log - jetty-6.1.8
0 [main] WARN org.geoserver.logging - Could not find configuration file for
logging
1310 [main] INFO /geoserver - Initializing Spring root WebApplicationContext
1451 [main] WARN org.springframework.beans.factory.config.CustomEditorConfigure
r - Passing PropertyEditor instances into CustomEditorConfigurer is deprecated:
use PropertyEditorRegistrars or PropertyEditor class names instead. Offending k
ey [org.geotools.util.Version; offending editor instance: org.geoserver.platform
.util.VersionPropertyEditor@anonymised.com
1716 [main] ERROR org.vfny.geoserver.global -
  • GEOSERVER_DATA_DIR: D:\Geoserver_data
    2106 [main] WARN org.geoserver - No ‘workspaces’ directory found, unable to lo
    ad any stores.
    3888 [main] WARN org.springframework.beans.factory.support.DisposableBeanAdapte
    r - Invocation of destroy method failed on bean with name ‘geoServerLoader’: or
    g.springframework.beans.factory.BeanCreationNotAllowedException: Error creating
    bean with name ‘GWCLifeCycleHandler’: Singleton bean creation not allowed while
    the singletons of this factory are in destruction (Do not request a bean from a
    BeanFactory in a destroy method implementation!)
    3888 [main] ERROR org.springframework.web.context.ContextLoader - Context initi
    alization failed
    org.springframework.beans.factory.BeanCreationException: Error creating bean wit
    h name ‘gwcFacade’ defined in URL [jar:file:/C:/geoserver-2.2.2/webapps/geoserve
    r/WEB-INF/lib/gwc-2.2.2.jar!/applicationContext.xml]: Cannot resolve reference t
    o bean ‘gwcTLDispatcher’ while setting constructor argument; nested exception is
    th name ‘geoServer’ defined in URL [jar:file:/C:/geoserver-2.2.2/webapps/geoserv
    er/WEB-INF/lib/main-2.2.2.jar!/applicationContext.xml]: Initialization of bean f
    ailed; nested exception is java.lang.RuntimeException: java.lang.NullPointerExce
    ption
    at org.springframework.beans.factory.support.BeanDefinitionValueResolver
    .resolveReference(BeanDefinitionValueResolver.java:328)
    .resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
    at org.springframework.beans.factory.support.ConstructorResolver.resolve
    ConstructorArguments(ConstructorResolver.java:630)
    at org.springframework.beans.factory.support.ConstructorResolver.autowir
    eConstructor(ConstructorResolver.java:148)
    at org.springframework.beans.factory.support.AbstractAutowireCapableBean
    Factory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
    Factory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
    Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
    Factory.createBean(AbstractAutowireCapableBeanFactory.java:456)
    at org.springframework.beans.factory.support.AbstractBeanFactory$1.getOb
    ject(AbstractBeanFactory.java:294)
    at org.springframework.beans.factory.support.DefaultSingletonBeanRegistr
    y.getSingleton(DefaultSingletonBeanRegistry.java:225)
    at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBe
    an(AbstractBeanFactory.java:291)
    at org.springframework.beans.factory.support.AbstractBeanFactory.getBean
    (AbstractBeanFactory.java:193)
    at org.springframework.beans.factory.support.DefaultListableBeanFactory.
    preInstantiateSingletons(DefaultListableBeanFactory.java:585)
    at org.springframework.context.support.AbstractApplicationContext.finish
    BeanFactoryInitialization(AbstractApplicationContext.java:913)
    at org.springframework.context.support.AbstractApplicationContext.refres
    h(AbstractApplicationContext.java:464)
    at org.springframework.web.context.ContextLoader.configureAndRefreshWebA
    pplicationContext(ContextLoader.java:385)
    at org.springframework.web.context.ContextLoader.initWebApplicationConte
    xt(ContextLoader.java:284)
    at org.springframework.web.context.ContextLoaderListener.contextInitiali
    zed(ContextLoaderListener.java:111)
    at org.geoserver.platform.GeoServerContextLoaderListener.contextInitiali
    zed(GeoServerContextLoaderListener.java:18)
    at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.
    java:540)
    at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
    at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.jav
    a:1220)
    at org.mortbay.jetty.handler.ContextHandler.doStart(ContextHandler.java:
    510)
    at org.mortbay.jetty.webapp.WebAppContext.doStart(WebAppContext.java:448
    at org.mortbay.component.AbstractLifeCycle.start(AbstractLifeCycle.java:
    39)
    at org.mortbay.jetty.handler.HandlerCollection.doStart(HandlerCollection
    .java:152)
    at org.mortbay.jetty.handler.ContextHandlerCollection.doStart(ContextHan
    dlerCollection.java:156)
    39)
    .java:152)
    39)
    at org.mortbay.jetty.handler.HandlerWrapper.doStart(HandlerWrapper.java:
    130)
    at org.mortbay.jetty.Server.doStart(Server.java:222)
    39)
    at org.mortbay.xml.XmlConfiguration.main(XmlConfiguration.java:977)
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
    java:39)
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
    sorImpl.java:25)
    at org.mortbay.start.Main.invokeMain(Main.java:183)
    at org.mortbay.start.Main.start(Main.java:497)
    at org.mortbay.start.Main.main(Main.java:115)
    Caused by: org.springframework.beans.factory.BeanCreationException: Error creati
    ng bean with name ‘geoServer’ defined in URL [jar:file:/C:/geoserver-2.2.2/webap
    ps/geoserver/WEB-INF/lib/main-2.2.2.jar!/applicationContext.xml]: Initialization
    of bean failed; nested exception is java.lang.RuntimeException: java.lang.NullP
    ointerException
    Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
    an(AbstractBeanFactory.java:284)
    .resolveReference(BeanDefinitionValueResolver.java:322)
    … 40 more
    Caused by: java.lang.RuntimeException: java.lang.NullPointerException
    at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(
    GeoServerLoader.java:135)
    at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitializa
    tion(GeoServerLoaderProxy.java:54)
    Factory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanF
    actory.java:394)
    Factory.initializeBean(AbstractAutowireCapableBeanFactory.java:1448)
    Factory.doCreateBean(AbstractAutowireCapableBeanFactory.java:519)
    … 48 more
    Caused by: java.lang.NullPointerException
    at org.geoserver.config.GeoServerLoader.readConfiguration(GeoServerLoade
    r.java:620)
    at org.geoserver.config.DefaultGeoServerLoader.loadGeoServer(DefaultGeoS
    erverLoader.java:68)
    GeoServerLoader.java:129)
    … 52 more
    5213 [main] ERROR org.mortbay.log - Failed startup of context org.mortbay.jetty.
    webapp.WebAppContext@anonymised.com{/geoserver,file:/C:/geoserver-2.2.2/webapps/geoserv er/}
    ption
    java:540)
    a:1220)
    510)
    39)
    .java:152)
    39)
    .java:152)
    39)
    130)
    39)
    java:39)
    sorImpl.java:25)
    ointerException
    … 40 more
    actory.java:394)
    … 48 more
    r.java:620)
    … 52 more
    5244 [main] ERROR org.mortbay.log - Nested in org.springframework.beans.factory.
    BeanCreationException: Error creating bean with name ‘gwcFacade’ defined in URL
    [jar:file:/C:/geoserver-2.2.2/webapps/geoserver/WEB-INF/lib/gwc-2.2.2.jar!/appli
    cationContext.xml]: Cannot resolve reference to bean ‘gwcTLDispatcher’ while set
    ting constructor argument; nested exception is org.springframework.beans.factory
    .BeanCreationException: Error creating bean with name ‘geoServer’ defined in URL
    [jar:file:/C:/geoserver-2.2.2/webapps/geoserver/WEB-INF/lib/main-2.2.2.jar!/app
    licationContext.xml]: Initialization of bean failed; nested exception is java.la
    ng.RuntimeException: java.lang.NullPointerException:
    r.java:620)
    actory.java:394)
    java:540)
    a:1220)
    510)
    39)
    .java:152)
    39)
    .java:152)
    39)
    130)
    39)
    java:39)
    sorImpl.java:25)
    5291 [main] INFO org.mortbay.log - Opened C:\geoserver-2.2.2\logs\2012_12_13.req
    uest.log
    5307 [main] INFO org.mortbay.log - Started SelectChannelConnector@anonymised.com:8082
Environment:
Windows 2008 R2 SP1
Project:
Priority:
CriticalCritical
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
