[Geoserver-devel] [jira] (GEOS-5505) Installing JP2000 extension
Jonathan Moules created BugGEOS-5505
Issue Type:
BugBug
Affects Versions:
2.2.2
Assignee:
Andrea Aime
Components:
Documentation
Created:
13/Dec/12 11:21 AM
Description:
I want to install the JPEG2000 extension. I go to Here: http://geoserver.org/display/GEOS/Stable and select it from the bottom.
It downloads, I place the files in /lib/ and it doesn’t seem to be there.
I open the readme and it says:
In order to install the ImageIO-Ext Kakadu extensions you have to:
  • copy all the jars contained in this package into geoserver/WEB-INF/lib
  • properly install the native binary libraries for your operating system
For the binary components and install instructions referer to:
http://geoserver.org/display/GEOSDOC/JP2K
Problem is, the link at the bottom of that doesn’t work. Where do I get the native binary libraries?
Project:
Priority:
MajorMajor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
