[Geoserver-devel] [jira] (GEOS-5520) GeoServer fails to serve Oracle Layer
Jonathan Moules created BugGEOS-5520
Issue Type:
BugBug
Affects Versions:
2.2.2
Assignee:
Andrea Aime
Components:
Oracle
Created:
21/Dec/12 8:42 AM
Description:
My Oracle Store is set up fine (its just an Oracle NG).
I then added a layer from the list and set it up with a style (default_polygon).
I’ve left most of everything on the default as I don’t know what they do. Its using 27700 SRS (what the data is).
Having finally got everything set up, I try and connect to it via QGIS but get this error:
Response: <?xml version=“1.0” encoding=“UTF-8”?><ServiceExceptionReport version=“1.3.0” xmlns=“http://www.opengis.net/ogc” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xsi:schemaLocation=“http://www.opengis.net/ogc http://wppgeog3:8082/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd”> <ServiceException code=“internalError”>
Rendering process failed
java.io.IOException
null
ORA-00942: table or view does not exist
</ServiceException></ServiceExceptionReport>
The table in question definitely exists and the user definitely has rights to read it.
Project:
Priority:
MajorMajor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
