[Geoserver-devel] [jira] (GEOS-5523) Document special behaviour for connection strings with oracle NG
Bernhard Kiselka created BugGEOS-5523
Issue Type:
BugBug
Affects Versions:
2.2.3
Assignee:
Andrea Aime
Components:
Documentation, Oracle
Created:
02/Jan/13 4:50 AM
Description:
  1. Update documentation
http://docs.geoserver.org/2.2.3/user/data/database/oracle.html
writing in the description of option database that also a connection to Oracle RAC with a connection string like
(DESCRIPTION=(ADDRESS=(PROTOCOL=TCP)(HOST=[host])(PORT=[port, often 1521]))(LOAD_BALANCE=YES)(CONNECT_DATA=(SERVICE_NAME=[oracle_service_name])))
i.e. starting with a “(” is also possible.
This will result in a connection string of
jdbc:oracle:thin:@[database]
so option host and port won’t be used then!
  1. Also add note that a option database starting with “/” will result in a connection string
    jdbc:oracle:thin:@//[host]:[port][database]
    instead of the standard
    jdbc:oracle:thin:@[host]:[port]:[database]
  2. Note: with GEOT-4361 also a connection to Oracle LDAP would be possible and should be documented as well as 1)!
Project:
Priority:
MinorMinor
Reporter:
Bernhard Kiselka
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
