[Geoserver-devel] [jira] (GEOS-5526) WFS "update" on partitioned postgres table will generate SELECT without using partition attribute
Marco Corsi created ImprovementGEOS-5526
WFS “update” on partitioned postgres table will generate SELECT without using partition attribute
Issue Type:
ImprovementImprovement
Affects Versions:
2.2.3, 2.1.4
Assignee:
Andrea Aime
Components:
WFS
Created:
03/Jan/13 4:47 AM
Description:
The problem is related to partitioned tables (using PostgreSQL / PostGIS database but probably it is still the same with other DBs).
When I use the WFS protocol (transaction / update) on the parent table it successfully update using partition attribute but, after, it goes in a “Post process update for boundary update and featureValidation” and this part of the code is not using partition attribute causing a full tablescan. Basically, if the table is really big (which is normally the case for using partitioned tables) this is causing the WFS to be not usable (too slow).
Environment:
Redhat 6
Project:
Priority:
MajorMajor
Reporter:
Marco Corsi
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
