[Geoserver-devel] [jira] (GEOS-5532) Renaming workspaces doesn't translate over to Tile Caches
Jonathan Moules created BugGEOS-5532
Renaming workspaces doesn’t translate over to Tile Caches
Issue Type:
BugBug
Affects Versions:
2.2.2
Assignee:
Andrea Aime
Created:
04/Jan/13 8:07 AM
Description:
I had created a workspace called “test” and added a few layers through it.
Some time later I then renamed it to “test_db”. In the layers view, this automatically translated across to the layers.
However, it doesn’t seem to have done so for the Tile Caches. If I look at the “Tile Layers” list I still have stuff like “Test:BOUNDARY_WSHIRE_DISTRICTS” showing up.
Possibly related, in my startup log, I was getting:
2013-01-04 13:40:22,445 WARN [org.geoserver.gwc.layer] - Can’t compute bounds for tile layer Test:OS_MM2_CONWY_TOPOGRAPHIC_AREA in CRS EPSG:27700. Assuming full GridSet bounds. (Argument “targetCRS” should not be null.)
I then deleted the layer entirely but got this error:
2013-01-04 13:42:05,240 ERROR [org.geoserver.gwc.layer] - GeoServer TileLayer named ‘Test:OS_MM2_CONWY_TOPOGRAPHIC_AREA’ with id ‘LayerInfoImpl-4bebb9a5:13bbdb3ef19:-7fff’ can’t be loaded. It will be removed from the configuration but you’ll need to delete its cache manually (if any). Original error message: GeoServer layer or layer group ‘LayerInfoImpl-4bebb9a5:13bbdb3ef19:-7fff’ does not exist
Project:
Priority:
CriticalCritical
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
