[Geoserver-devel] [jira] (GEOS-5537) Tiling artifacts with RasterSymbolizer using bilinear interpolation
Mike Benowitz created BugGEOS-5537
Issue Type:
BugBug
Affects Versions:
2.2.3
Assignee:
Andrea Aime
Components:
WMS
Created:
07/Jan/13 2:16 PM
Description:
With interpolation set to Bilinear in the GeoServer WMS configuration, rendering a raster layer using a RasterSymbolizer with a “ramp” color map results in very noticeable discontinuities at tile boundaries (in clients that tile WMS GetMap requests, such as World Wind Java).
Project:
Priority:
MajorMajor
Reporter:
Mike Benowitz
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
Mike Benowitz reopened BugGEOS-5537
Thanks for looking at this. However, after applying your fix the only difference I see is that the land boundaries look rougher. The tiling artifacts are still there (see new image attached).
Change By:
Mike Benowitz (09/Jan/13 1:48 PM)
Status:
Resolved Reopened
Resolution:
Fixed
