Issue Type:
Bug
Affects Versions:
2.2.3
Assignee:
Andrea Aime
Components:
WFS
Created:
09/Jan/13 10:51 AM
Description:
I posted this to the Mailing list but received no reply.
Looking at “layer preview” in 2.2.3, at the very bottom, as WFS there’s an entry that says:
“application/gml+xml; version=3.2”
if I click this I get:
<ServiceExceptionReport version=“1.2.0” xmlns=“http://www.opengis.net/ogc” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xsi:schemaLocation=“http://www.opengis.net/ogc http://schemas.opengis.net/wfs/1.0.0/OGC-exception.xsd”>
<ServiceException>
java.lang.RuntimeException: No response: ( object = class org.geoserver.wfs.request.FeatureCollectionResponse$WFS11, outputFormat = application/gml xml; version=3.2 ) No response: ( object = class org.geoserver.wfs.request.FeatureCollectionResponse$WFS11, outputFormat = application/gml xml; version=3.2 )
</ServiceException>
</ServiceExceptionReport>
It doesn’t seem to matter which layer I use it for.
When I load the layer preview page, the following “information” appears in the console, may be applicable as 3.2 appears far more often than the others:
09 Jan 16:50:13 WARN [org.geoserver.web] - Unable to find property: ‘format.wms.image/png; mode=8bit’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
09 Jan 16:50:13 WARN [org.geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kmz xml’ for component: [class=org.geoserver.web.demo.MapPreviewPag
09 Jan 16:50:13 WARN [org.geoserver.web] - Unable to find property: ‘format.wms.application/vnd.google-earth.kmz’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
09 Jan 16:50:13 WARN [org.geoserver.web] - Unable to find property: ‘format.wms.kmz’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
09 Jan 16:50:13 WARN [org.geoserver.web] - Unable to find property: ‘format.wms.openlayers’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
09 Jan 16:50:13 WARN [org.geoserver.web] - Unable to find property: ‘format.wms.text/html’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
09 Jan 16:50:13 WARN [org.geoserver.web] - Unable to find property: ‘format.wms.atom’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
09 Jan 16:50:13 WARN [org.geoserver.web] - Unable to find property: ‘format.wms.application/atom xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
09 Jan 16:50:13 WARN [org.geoserver.web] - Unable to find property: ‘format.wms.application/xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
09 Jan 16:50:13 WARN [org.geoserver.web] - Unable to find property: ‘format.wms.image/svg’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
09 Jan 16:50:13 WARN [org.geoserver.web] - Unable to find property: ‘format.wms.image/svg xml’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
09 Jan 16:50:13 WARN [org.geoserver.web] - Unable to find property: ‘format.wfs.application/gml+xml; version=3.2’ for component: [class=org.geoserver.web.demo.MapPreviewPage]
Project:
Priority:
Minor
Reporter:
Jonathan Moules
If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa).
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
