[Geoserver-devel] [jira] (GEOS-5549) up/down arrows with LayerGroups
Jonathan Moules created BugGEOS-5549
Issue Type:
BugBug
Affects Versions:
2.2.3
Assignee:
Andrea Aime
Components:
UI
Created:
10/Jan/13 10:04 AM
Description:
Blank new layer group.
If I add one layer, there are no up/down arrows next to it. Good.
  • If I add a second layer, this layer has an up arrow, but the first layer doesn’t get a “down” arrow. Same if I add more layers.
  • If I a top or bottom layer the layer that replaces it at the top/bottom doesn’t get its arrow updated to reflect this.
To get them to appear correctly, I have to save the group and then open it again. But even then, removing/adding layers causes the above to happen.
Project:
Priority:
MinorMinor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
