[Geoserver-devel] [jira] (GEOS-5556) count=0 - WFS GetFeature
Jonathan Moules created BugGEOS-5556
Issue Type:
BugBug
Affects Versions:
2.2.3
Assignee:
Andrea Aime
Components:
WFS
Created:
11/Jan/13 9:26 AM
Description:
If I send a WFS GetFeature request with a value of 0 (it was accidental!), I get back a GeoServer error in my exceptionText:
<ows:ExceptionText>java.lang.ArrayIndexOutOfBoundsException: 0
0</ows:ExceptionText>
(and there’s a corresponding console error):
11 Jan 15:17:31 ERROR [org.geoserver.ows] -
at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.buildSchemaInternal(FeatureTypeSchemaBuilder.java:244)
at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.build(FeatureTypeSchemaBuilder.java:147)
at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.build(FeatureTypeSchemaBuilder.java:135)
at org.geoserver.wfs.xml.ApplicationSchemaXSD2.buildSchema(ApplicationSchemaXSD2.java:69)
This implies that the input isn’t being properly sanitised.
As best I can tell trying to read the WFS 2.0.0 spec, exceptions for GetFeature should be either OperationParsingFailed or OperationProcessingFailed (the later in this case I guess).
Project:
Priority:
MajorMajor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
