[Geoserver-devel] [jira] (GEOS-5591) Can't seed tiles with bounding box
Jonathan Moules created BugGEOS-5591
Can’t seed tiles with bounding box
Issue Type:
BugBug
Assignee:
Andrea Aime
Components:
GWC
Created:
21/Jan/13 11:27 AM
Description:
I’m trying to seed tiles for a layer. This works fine with no specified bounding box (left empty). But if I enter a bounding box, when I click to start seeding, the page returns only “11”.
It doesn’t matter if the box is in the native projection of the data (27700) or WGS:84, same result.
This appears in my console:
21 Jan 17:22:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Converted URL to lowercase, from: ‘/gwc/rest/seed/test_db:os_mm_boundaryline’; to: ‘/gwc/rest/seed/test_d
b:os_mm_boundaryline’ and httpMethod= POST
21 Jan 17:22:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - ~~~~~~~~~~ antPath= /** methodList= [Ljava.lang.String;@1b2381b
21 Jan 17:22:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - method[0]: GET
21 Jan 17:22:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/gwc/rest/seed/test_db:os_mm_boundaryline’; antPath is /; matchedPath=true; matchedMetho
ds=false
methodList= [Ljava.lang.String;@1dcd04a
21 Jan 17:22:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - method[0]: POST
21 Jan 17:22:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - method[1]: DELETE
21 Jan 17:22:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - method[2]: PUT
21 Jan 17:22:59 DEBUG [org.geoserver.security.RESTfulPathBasedFilterInvocationDefinitionMap] - Candidate is: ‘/gwc/rest/seed/test_db:os_mm_boundaryline’; antPath is /**; matchedPath=true; matchedMetho
ds=true
21 Jan 17:22:59 DEBUG [org.geoserver.ows.OWSHandlerMapping] - No handler mapping found for [/gwc/rest/seed/Test_DB:OS_MM_BOUNDARYLINE]
21 Jan 17:22:59 WARN [org.geowebcache.layer.MetaTile] - ********* Native JAI is not installed, meta tile cropping may be slow ********
21 Jan 17:22:59 DEBUG [org.geoserver.gwc.layer] - –> GWC Seeder Thread-1 submitting getMap request for meta grid location [0, 0, 11] on org.geoserver.gwc.layer.GeoServerMetaTile@anonymised.com
21 Jan 17:22:59 INFO [org.geoserver.wms] -
Request: getServiceInfo
21 Jan 17:22:59 DEBUG [org.geoserver.ows] - Getting layers and styles from LAYERS and STYLES
Project:
Priority:
MajorMajor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
