[Geoserver-devel] [jira] (GEOS-5594) JAVA_OPTS variable not functioning
Jonathan Moules created BugGEOS-5594
Issue Type:
BugBug
Affects Versions:
2.2.3
Assignee:
Justin Deoliveira
Components:
Configuration
Created:
22/Jan/13 11:34 AM
Description:
If I set a JAVA_OPTS environmental variable to something like:
-Xmx1G -Xms128m -XX:MaxPermSize=256m -XX:SoftRefLRUPolicyMSPerMB=36000 -XX:+UseParallelGC
GeoServer won’t start, citing an invalid heap size. What its actually doing is only getting the “-Xmx1G” from the variable because of the poor way windows handles spaces in them.
If I change JAVA_OPTS to:
“-Xmx1G -Xms128m -XX:MaxPermSize=256m -XX:SoftRefLRUPolicyMSPerMB=36000 -XX:+UseParallelGC”
(note the quotes around it). It still doesn’t start, but this time instantly closes the batch file.
The only way to get it to run using options is to edit the batch file and declare it there. I.e. line 116 becomes:
if “%JAVA_OPTS%” == “” (set JAVA_OPTS=“-Xmx1G -Xms128m -XX:MaxPermSize=256m -XX:SoftRefLRUPolicyMSPerMB=36000 -XX:+UseParallelGC”)
or I guess just stick it directly into line 121.
Environment:
Windows 2008 R2
Project:
Priority:
MinorMinor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
