[Geoserver-devel] [jira] (GEOS-5606) Add a possibility to obtain a forgotten master password
Christian Mueller created ImprovementGEOS-5606
Issue Type:
ImprovementImprovement
Affects Versions:
2.3-beta1
Assignee:
Christian Mueller
Components:
Security
Created:
26/Jan/13 9:16 AM
Description:
Add a simple page on the GUI giving an admin the possibility to dump the master password to a file.
The name of the file acts as the shared secret between the admin and GeoServer.
There is a new public API
GeoserverSecurityManager.dumpMasterPassword(File file)
The following countermeasures should prevent misuse:
  1. The code triggers a stack trace and checks the caller. At the moment, only two methods are allowed to call this method, one test method and a second method
MasterPasswordInfoPage.dumpMasterPassword()
  1. The MasterPasswordInfoPage class has package visibility (all members too).
  2. The above class is in the package org.geoserver.security.web.password. This package is sealed.
Fix Versions:
2.3-RC1
Project:
Priority:
MajorMajor
Reporter:
Christian Mueller
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
