[Geoserver-devel] [jira] (GEOS-5643) problem with legend decoration and input parameter
Hans-Joachim Kliemeck created BugGEOS-5643
Issue Type:
BugBug
Affects Versions:
2.2.4
Assignee:
Andrea Aime
Created:
07/Feb/13 5:31 AM
Description:
currently the options that are inserted on the LegendDecoration are used for the getLegendGraphic request too (legend_options). the decoration is using org.geoserver.ows.util.CaseInsensitiveMap that does not rewrite the keys if a whole map is inserted. the map should rewrite the keys wheather just one entry is inserted or a whole map
Project:
Priority:
MinorMinor
Reporter:
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
