[Geoserver-devel] [jira] (GEOS-5650) Build failure in wps-core SnapTest on one host only
Ben Caradoc-Davies created BugGEOS-5650
Issue Type:
BugBug
Affects Versions:
2.4-beta
Assignee:
Andrea Aime
Components:
WPS
Created:
11/Feb/13 10:12 PM
Description:
I am seeing a repeatable build failure in wps-core SnapTest but only on one box (Jenkins):
https://cgsrv8.arrc.csiro.au/jenkins/view/geoserver-master/job/geoserver-master/1008/
Buried in the stdout is this:
org.geoserver.wps.WPSException: Unknown process gs:Snap
Two boxes are Debian running Maven 3 with JDK 6 64-bit. One fails one does not. Changing test runOrder does not reproduce the failure.
Failure occurs since this commit (but I cannot see why):
commit 2afcb15d6bed30c25df347cba1afc20372925de2
Merge: 5554034 1328dcd
Author: Justin Deoliveira <jdeolive@anonymised.com>
Date:   Mon Feb 11 11:59:20 2013 -0800
    Merge pull request #119 from jdeolive/wps_events
    preventing WPSInitializer from producing unecessary event traffic
Maven report:
Test set: org.geoserver.wps.SnapTest
Tests run: 10, Failures: 10, Errors: 0, Skipped: 0, Time elapsed: 2.01 sec <<< FAILURE!
testFeatureCollectionInline4326Raw(org.geoserver.wps.SnapTest)  Time elapsed: 1204 sec  <<< FAILURE!
junit.framework.ComparisonFailure: expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
	at junit.framework.Assert.assertEquals(Assert.java:85)
	at junit.framework.Assert.assertEquals(Assert.java:91)
	at org.geoserver.wps.SnapTest.testFeatureCollectionInline4326Raw(SnapTest.java:74)
testFeatureCollectionInline4326Doc(org.geoserver.wps.SnapTest)  Time elapsed: 119 sec  <<< FAILURE!
junit.framework.ComparisonFailure: expected:<[wps:ExecuteResponse]> but was:<[ows:ExceptionReport]>
	at org.geoserver.wps.SnapTest.testFeatureCollectionInline4326Doc(SnapTest.java:114)
testFeatureCollectionInline3338Raw(org.geoserver.wps.SnapTest)  Time elapsed: 102 sec  <<< FAILURE!
	at org.geoserver.wps.SnapTest.testFeatureCollectionInline3338Raw(SnapTest.java:156)
testFeatureCollectionInline3338Doc(org.geoserver.wps.SnapTest)  Time elapsed: 72 sec  <<< FAILURE!
	at org.geoserver.wps.SnapTest.testFeatureCollectionInline3338Doc(SnapTest.java:200)
testFeatureCollectionInternalWFSRaw(org.geoserver.wps.SnapTest)  Time elapsed: 60 sec  <<< FAILURE!
	at org.geoserver.wps.SnapTest.testFeatureCollectionInternalWFSRaw(SnapTest.java:243)
testFeatureCollectionWFSFilter1Raw(org.geoserver.wps.SnapTest)  Time elapsed: 61 sec  <<< FAILURE!
	at org.geoserver.wps.SnapTest.testFeatureCollectionWFSFilter1Raw(SnapTest.java:296)
testFeatureCollectionWFSFilter2Raw(org.geoserver.wps.SnapTest)  Time elapsed: 72 sec  <<< FAILURE!
	at org.geoserver.wps.SnapTest.testFeatureCollectionWFSFilter2Raw(SnapTest.java:351)
testMissingFeatures(org.geoserver.wps.SnapTest)  Time elapsed: 57 sec  <<< FAILURE!
junit.framework.AssertionFailedError: Expecting to find matches for Xpath //wps:Status/wps:ProcessFailed
	at junit.framework.Assert.fail(Assert.java:50)
	at junit.framework.Assert.assertTrue(Assert.java:20)
	at org.custommonkey.xmlunit.XMLAssert.assertXpathExists(XMLAssert.java:901)
	at org.geoserver.wps.SnapTest.testMissingFeatures(SnapTest.java:384)
testMissingPoint(org.geoserver.wps.SnapTest)  Time elapsed: 122 sec  <<< FAILURE!
	at org.geoserver.wps.SnapTest.testMissingPoint(SnapTest.java:412)
testWrongCRS(org.geoserver.wps.SnapTest)  Time elapsed: 119 sec  <<< FAILURE!
	at org.geoserver.wps.SnapTest.testWrongCRS(SnapTest.java:452)
All failures have stdout like this:
12 Feb 11:04:01 ERROR [geoserver.ows] -
	at org.geoserver.wps.executor.ExecuteRequest.getProcessInputs(ExecuteRequest.java:89)
	at org.geoserver.wps.executor.WPSExecutionManager.submit(WPSExecutionManager.java:103)
	at org.geoserver.wps.Execute.run(Execute.java:71)
	at org.geoserver.wps.DefaultWebProcessingService.execute(DefaultWebProcessingService.java:76)
	at sun.reflect.GeneratedMethodAccessor180.invoke(Unknown Source)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
	at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
	at $Proxy25.execute(Unknown Source)
	at sun.reflect.GeneratedMethodAccessor179.invoke(Unknown Source)
	at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
	at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
	at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1355)
	at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
	at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1374)
	at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1309)
	at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1291)
	at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1118)
	at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1053)
	at org.geoserver.test.GeoServerSystemTestSupport.post(GeoServerSystemTestSupport.java:1033)
	at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1252)
	at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1235)
	at org.geoserver.wps.SnapTest.testMissingPoint(SnapTest.java:409)
Project:
Priority:
CriticalCritical
Reporter:
Ben Caradoc-Davies
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
