[Geoserver-devel] [jira] (GEOS-5652) Password problem when creating PostGIS store via REST api
Benjamin Trigona-Harany created BugGEOS-5652
Issue Type:
BugBug
Affects Versions:
2.3-beta1
Assignee:
Andrea Aime
Components:
REST
Created:
12/Feb/13 2:01 PM
Description:
New PostGIS datastores created with the REST api will have the following element in their backing xml:
<entry key="password">password123</entry>
However, the ui reads from and writes to:
<entry key="passwd">crypt1:I2qHsAdFvJa2quNzldGedw==</entry>
Therefore, after the datastore is created, it can’t connect to Postgres, the password field in the ui is blank and, once the password is set through the ui, the unencrypted password remains in the backing xml.
Project:
Priority:
MajorMajor
Reporter:
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
