[Geoserver-devel] [jira] (GEOS-5653) Error setting JAVA_OPTS in startup.sh
Russ Hore created BugGEOS-5653
Issue Type:
BugBug
Affects Versions:
2.3-beta1
Assignee:
Justin Deoliveira
Components:
Configuration
Created:
13/Feb/13 2:56 AM
Description:
The startup.sh script in <geoserver home>/bin does not set the JAVA_OPTS variable correctly, it uses JAVA_OPS
It says
if [ -z “$JAVA_OPS” ]; then
set JAVA_OPS=-XX:MaxPermSize=128m
fi
whilst it should be
if [ -z “$JAVA_OPTS” ]; then
set JAVA_OPTS=-XX:MaxPermSize=128m
fi
Environment:
Linux
Project:
Priority:
MinorMinor
Reporter:
Russ Hore
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
