[Geoserver-devel] [jira] (GEOS-5659) Every WFS update leaks memory in the GWC WFS listener
Gabriel Roldán created BugGEOS-5659
Issue Type:
BugBug
Affects Versions:
2.2.4
Assignee:
Gabriel Roldán
Components:
GWC
Created:
15/Feb/13 10:47 AM
Description:
Originally reported at GWC’s issue tracker:
Using the packaged GWC integration with GeoServer 2.2
Steps to reproduce
  1. We have the web cache integration turned on
  2. Configure the WFS layer to be cached
  3. Update WFS layers regularly via rest (our updates can happen as often as every second)
  4. GWC integration uses a TransactionPlugin to listen for WFS Transaction commits and automatically truncates the appropriate tiles from the associated tile layers
  5. This truncate starts several tasks (1 per projection/format pair)
Results
Each task gets a reference in the TileBreeder.currentPool
Our testing shows that eventually GeoServer runs out of memory
Expected Results
TileBreeder.drain is called periodically to remove completed tasks
Workaround
Visit http://:8080/geoserver/gwc/rest/seed.json which will trigger the TileBreeder.drain method and free up the memory.
Project:
Priority:
MajorMajor
Reporter:
Gabriel Roldán
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa). For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
