Tobias Warneke created GEOS-5665 |
Issue Type: |
Bug |
Affects Versions: |
2.3-beta1 |
Assignee: |
Components: |
WMS |
Created: |
27/Feb/13 10:11 AM |
Description: |
Following your example “Extracting vertices” in I wanted to print the coordinate of each vertex using this sld snip: <FeatureTypeStyle> For simplicity I first want to print “TEST” for each vertex. But I got only one text for each main geometry and not one text for every extracted vertex. Using the PointSymbolizer example from you results in “squares” for each vertex as expected. |
Project: |
Priority: |
Major |
Reporter: |
