Jonathan Moules created GEOS-5684 |
Issue Type: |
Improvement |
Affects Versions: |
2.3-RC1 |
Assignee: |
Components: |
Configuration |
Created: |
05/Mar/13 6:15 AM |
Description: |
GeoServer currently keeps the configuration files and the data files in separate directories for the most part. This is useful for backing up the config/data separately using different strategies. However, the /gwc directory doesn’t follow this philosophy. Inside it, as well as tile cache directories, there’s also the quota (geowebcache-diskquota.xml) and gridset (geowebcache.xml) configuration. I believe these two files should be stored elsewhere from this directory to be in-keeping with the philosophy for the rest of the file-structure. Using web.xml <param-name>GEOWEBCACHE_CACHE_DIR</param-name> doesn’t resolve this - it just moves the two xml files with the data. |
Project: |
Priority: |
Major |
Reporter: |
