[Geoserver-devel] [jira] (GEOS-5685) GeoWebCache not WMS 1.3.0 compliant
Jonathan Moules created BugGEOS-5685
Issue Type:
BugBug
Affects Versions:
2.3-RC1
Assignee:
Andrea Aime
Components:
GWC
Created:
05/Mar/13 7:18 AM
Description:
I have GWC enabled and the “direct integration” option enabled. This works for WMS 1.1.0, but when I send a WMS 1.3.0 request, I get this in my headers:
geowebcache-miss-reason exception occurred: NumberFormatException: For input string: “x-ogc:def:crs:EPSG:27700”
I’m guessing this means it won’t work with any projections if all the 1.3.0 stuff is the same format.
This raises a few issues:
a) GWC integration shouldn’t try and intercept 1.3.0 requests if it doesn’t support them.
b) The toggle checkbox should say “Enable direct integration with GeoServer WMS 1.1.0” until 1.3.0 is supported. As it stands, it can mislead someone into thinking all GeoServer supported WMS versions are supported by GWC.
Project:
Priority:
MajorMajor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
