[Geoserver-devel] [jira] (GEOS-5687) Support custom dimensions for vector layers
Justin Deoliveira created ImprovementGEOS-5687
Issue Type:
ImprovementImprovement
Assignee:
Justin Deoliveira
Components:
UI, WMS
Created:
05/Mar/13 3:59 PM
Description:
At the moment custom dimensions are only supported for raster data. Extending to vectors should involve at a high level:
  • Extend/refactor the current code that handles time/elevation making it a bit more generic, including the code that:
    • Translates into filters for the backend datastore
    • Calculates the distinct values for the dimension
  • Update GetMap to pull out custom dimension info from request
  • Update GetCapabilities to include custom dimensions for vectors
  • Update the UI accordingly
Project:
Priority:
MajorMajor
Reporter:
Justin Deoliveira
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
