[Geoserver-devel] [jira] (GEOS-5703) TurboJPEG issue: BandSelect on images with alpha
Daniele Romagnoli created BugGEOS-5703
Issue Type:
BugBug
Affects Versions:
2.2.5
Assignee:
Andrea Aime
Components:
Community modules
Created:
12/Mar/13 12:19 PM
Description:
JPEG encoding doesn’t support alpha band.
Before sending the image to the TurboJPEGImageWriter, bandSelect is performed by TurboJPEGImageWorker to remove the alpha band.
When Medialib is available the result is good.
However, when MediaLib isn’t available the resulting image isn’t good (it is a bit stretched and dark lines are present).
It seems like the pure java BandSelect op doesn’t properly operate on the underlying DataBuffer when creating a child of the original tile or some other strange things are occurring within the Oracle ByteInterleavedRaster class.
We should investigate on it or create an utility method inside the TurboJpegImageWorker which uses a different approach to do bandSelect when no MediaLib is available.
Fix Versions:
2.2.x
Project:
Priority:
MajorMajor
Reporter:
Daniele Romagnoli
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your [JIRA administrators](https://jira.codehaus.org/secure/ContactAdministrators!default.jspa) For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
