Jonathan Moules created GEOS-5719 |
Issue Type: |
Bug |
Affects Versions: |
2.3-RC1 |
Assignee: |
Components: |
Oracle |
Created: |
19/Mar/13 4:25 AM |
Description: |
I have a layer in Oracle that for whatever reason returns NULL when I manually run: The issue is, if I use the “compute from data” on that layer, GeoServer fills in with these values: 0,0,-1,-1 That’s obviously invalid. GeoServer should do some basic sanity checking of the result and can fall back to the slow-method when it receives a null. |
Project: |
Priority: |
Minor |
Reporter: |
