[Geoserver-devel] [jira] (GEOS-5720) Easy one - Secruity service/layer properties file mistakes
Jonathan Moules created BugGEOS-5720
Issue Type:
BugBug
Affects Versions:
2.3.0
Assignee:
Andrea Aime
layers.properties
Components:
Security
Created:
19/Mar/13 9:23 AM
Description:
There are several issues here:
a) The layers.properties file referred to “namespaces”. They’re now workspaces.
b) Some minor typos in there and incomplete information
(Those two are both fixed in my attached file).
c) There’s a “service.properties” and a “services.properties”. The documentation says its the later, but its the former that actually contains stuff (the later only has a timestamp). One needs to be deleted.
d) Inside the layers.properties file it says “# Workspace: A workspace or * to catch them all (in that case, layer should be *)”
However, the bit in brackets isn’t referenced in the help. It should be in the help if its true, or removed from the file if not.
Project:
Priority:
MinorMinor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
