[Geoserver-devel] [jira] (GEOS-5725) Monitor plugin causes request failure when versions mismatch
Justin Deoliveira created BugGEOS-5725
Issue Type:
BugBug
Assignee:
Justin Deoliveira
Created:
25/Mar/13 9:27 AM
Description:
The plugin looks up request object information dynamically. Another potential issue is not catching request object model changes with the compiler. The monitor plugin should never cause a request to fail so some defensive checks are in order.
Project:
Priority:
MajorMajor
Reporter:
Justin Deoliveira
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
