Jonathan Moules created GEOS-5727 |
Issue Type: |
Bug |
Affects Versions: |
2.3.0 |
Assignee: |
Components: |
Security |
Created: |
26/Mar/13 4:38 AM |
Description: |
When using the “Test connection” function: a) If the Server URL is just slightly wrong, and there’s a “User Lookup Pattern” specified, the following Java error is returned: java.lang.StringIndexOutOfBoundsException: String index out of range: -1 b) If no Username or Password is entered, the following error appears: java.lang.NullPointerException There may be other aspects of this form which also don’t have validation, but I don’t know enough about LDAP to use/test them. |
Project: |
Priority: |
Major |
Reporter: |
