Andrea Aime created GEOS-5730 |
Issue Type: |
Bug |
Affects Versions: |
2.3.0 |
Assignee: |
Components: |
Security |
Created: |
26/Mar/13 8:46 AM |
Description: |
GRAVE: The web application [/geoserver] created a ThreadLocal with key of type [java.lang.ThreadLocal] (value [java.lang.ThreadLocal@anonymised.com]) and a value of type [org.springframework.security.core.context.SecurityContextImpl] (value [org.springframework.security.core.context.SecurityContextImpl@anonymised.com: Null authentication]) but failed to remove it when the web application was stopped. This is very likely to create a memory leak. Hum… maybe it’s just the spring security context holder, wondering, isn’t Spring doing anything to remove it at the end of the request? If not, we should do so ourselves Potentially related conversation: |
Project: |
Priority: |
Major |
Reporter: |
