[Geoserver-devel] [jira] (GEOS-5731) Tomcat complains about XSD/EMF related thread locals on shutdown/undeploy
Andrea Aime created BugGEOS-5731
Issue Type:
BugBug
Affects Versions:
2.3.0
Assignee:
Justin Deoliveira
Created:
26/Mar/13 8:48 AM
Description:
26-mar-2013 14.42.58 org.apache.catalina.loader.WebappClassLoader checkThreadLocalMapForLeaks
GRAVE: The web application [/geoserver] created a ThreadLocal with key of type [org.eclipse.emf.ecore.xml.type.util.XMLTypeUtil.CharArrayThreadLocal] (value [org.eclipse.emf.ecore.xml.type.util.XMLTypeUtil$CharArrayThreadLocal@anonymised.com]) and a value of type [char] (value [[C@anonymised.com]) but failed to remove it when the web application was stopped. This is very likely to create a memory leak.
GRAVE: The web application [/geoserver] created a ThreadLocal with key of type [org.eclipse.emf.ecore.impl.EClassImpl$1] (value [org.eclipse.emf.ecore.impl.EClassImpl$1@anonymised.com]) and a value of type [java.util.HashSet] (value []) but failed to remove it when the web application was stopped. This is very likely to create a memory leak.
Not sure what might have created those though…
Project:
Priority:
MajorMajor
Reporter:
Andrea Aime
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
