[Geoserver-devel] [jira] (GEOS-5743) Build failure in gwc caused by upstream ParameterFilter changes
Ben Caradoc-Davies created BugGEOS-5743
Issue Type:
BugBug
Assignee:
Andrea Aime
Components:
GWC
Created:
01/Apr/13 8:50 PM
Description:
I have confirmed the build failure locally as well. OpenGeo Hudson seems hung.
-------- Original Message --------
Subject: [ExternalEmail] [Geoserver-devel] geowebcache-master ParameterFilter changes break geoserver-master build in gwc
Date: Tue, 2 Apr 2013 09:43:26 +0800
To: ksmith, Gabriel Roldán
CC: geoserver-devel@lists.sourceforge.net
Kevin and Gabriel,
it looks like recent geowebcache-master ParameterFilter changes break
geoserver-master in the gwc module:
https://cgsrv8.arrc.csiro.au/jenkins/view/geoserver-master/job/geoserver-master/1232/
https://cgsrv8.arrc.csiro.au/jenkins/view/geoserver-master/job/geoserver-master/org.geoserver$gwc/1232/testReport/
java.lang.UnsupportedOperationException
	at java.util.AbstractList.add(AbstractList.java:131)
	at java.util.AbstractList.add(AbstractList.java:91)
	at java.util.AbstractCollection.addAll(AbstractCollection.java:305)
	at
org.geoserver.gwc.layer.TileLayerInfoUtil.updateStringParameterFilter(TileLayerInfoUtil.java:167)
I have kicked the build on OpenGeo Hudson to generate your official
notification (our Jenkins polls more frequently).  ;-)
Kind regards,
Ben Caradoc-Davies
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Project:
Priority:
BlockerBlocker
Reporter:
Ben Caradoc-Davies
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
