Christian Mueller created GEOS-5753 |
Issue Type: |
Improvement |
Affects Versions: |
2.3.0 |
Assignee: |
Created: |
08/Apr/13 3:34 AM |
Description: |
The JDBC Authentication Provider authenticates a user by establishing a JDBC connection. On the config GUI, there is no possibility to test the JDBC Connect URL with the specified JDBC Driver. This improvement adds a username field, a password field and a connect button. The idea is to avoid problems after activating such a provider. An erroneous provider may force a root login or manipulation of security configuration files directly. |
Project: |
Priority: |
Major |
Reporter: |
