albert valls created GEOS-5763 |
Issue Type: |
Bug |
Affects Versions: |
2.3.0 |
Assignee: |
Attachments: |
logs.txt |
Components: |
WMS |
Created: |
11/Apr/13 10:00 AM |
Description: |
Creating a new datasource for WMS cascading with some server, fail when the check “Use HTTP connection pooling” is turned on. Could not list layers for this store, an error occurred retrieving them: null It happens only with some ArcGIS servers like: turning off connection pooling makes it work perfectly. Made some testing and realized that saving the capabilities file and serving it in: I have attached the server log, hope it helps. Ask if you need further details. |
Environment: |
Geoserver 2.3.0 on Tomcat 7. |
Project: |
Labels: |
wms geoserver |
Priority: |
Minor |
Reporter: |
