Issue Type: |
Bug |
Affects Versions: |
2.3.0 |
Assignee: |
Attachments: |
image.png, Poole-Proposals Map (3).pdf |
Components: |
SQLServer |
Created: |
16/Apr/13 5:21 AM |
Description: |
When I try to run layer previews of my data I get the following image (attached). For some reason this is the same if I try to preview in Open Layers, but if I print to PDF it works fine (attached). Any suggestions as to what I need to do to fix this quirk would be greatfully received. Thanks |
Project: |
Priority: |
Minor |
Reporter: |
