Issue Type:
Improvement
Assignee:
Niels Charlier
Components:
Application schema
Created:
18/Apr/13 5:29 AM
Description:
Support Sort-BY in App-schema, however with two limitations:
- Sorting on nested feature properties is not possible.
- Sorting works with an attribute that is mapped to a simple attribute in the database, however does not support mappigns to expressions. When the sorting attribute is mapped to an expression, the attribute names are simply extracted from it and app-schema sorts on those. This however does not guarantee that the sorting is in order with the value of the evaluated expressions.
Project:
Priority:
Major
Reporter:
Niels Charlier
If you think it was sent incorrectly, please contact your JIRA administrators
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
