Laszlo Sores created GEOS-5787 |
Issue Type: |
Bug |
Affects Versions: |
2.3.0 |
Assignee: |
Created: |
23/Apr/13 7:58 AM |
Description: |
For a GetFeatureInfo Request Geoserver 2.3.1 sends a HTTP Response that do not contain charset definition in the header. This is true for text/plain format. In this situation clients may fail to read the text properly if encoding is other than ISO-8859-1. (pe. UTF-8) In a concrete situation a Geonetwork client failed to render FeatureInfo in the Map Viewer window |
Fix Versions: |
1.7.2 |
Project: |
Priority: |
Major |
Reporter: |
