[Geoserver-devel] [jira] (GEOS-5796) X-Paths with predicates only work with @attribute is references
Niels Charlier created BugGEOS-5796
Issue Type:
BugBug
Assignee:
Niels Charlier
Components:
Application schema
Created:
30/Apr/13 7:05 AM
Description:
In post-filters, the JXPATH library is used to evaluate x-paths, which automatically supports predicates. So far I had always assumed this worked perfectly, but it seems that all my tests used a @attribute inside the predicate. If another type of x-path is used inside the predicate, the predicate fails. For example: gn:GeographicalName[gn:language=“french”]
Project:
Priority:
MajorMajor
Reporter:
Niels Charlier
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
