Niels, I see some online test build failures after this change:
https://cgsrv8.arrc.csiro.au/jenkins/job/geoserver-master-app-schema-online-test/745/
org.geoserver.test.XPathPredicateTest.testFiltering
Failing for the past 1 build (Since Failed#745 )
Took 10 sec.
Error Message
expected:<2> but was:<0>
Stacktrace
java.lang.AssertionError: expected:<2> but was:<0>
at org.junit.Assert.fail(Assert.java:88)
at org.junit.Assert.failNotEquals(Assert.java:743)
at org.junit.Assert.assertEquals(Assert.java:118)
at org.junit.Assert.assertEquals(Assert.java:555)
at org.junit.Assert.assertEquals(Assert.java:542)
at org.geoserver.test.AbstractAppSchemaTestSupport.assertXpathCount(AbstractAppSchemaTestSupport.java:358)
at org.geoserver.test.XPathPredicateTest.testFiltering(XPathPredicateTest.java:61)
org.geoserver.test.XPathPredicateTest.testGetPropertyValue
Took 39 ms.
Error Message
Stacktrace
at org.geoserver.test.XPathPredicateTest.testGetPropertyValue(XPathPredicateTest.java:75)
Change By:
Ben Caradoc-Davies (23/May/13 8:40 PM)
Status:
Resolved Reopened
Resolution:
Fixed
If you think it was sent incorrectly, please contact your JIRA administrators
For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
