[Geoserver-devel] [jira] (GEOS-5810) Packaging error for the CAS extension
Christian Mueller created BugGEOS-5810
Issue Type:
BugBug
Affects Versions:
2.3.1
Assignee:
Andrea Aime
cas-client-core-3.1.12.jar
Components:
Security
Created:
12/May/13 5:07 AM
Description:
The zip file on the download page http://geoserver.org/display/GEOS/Stable for the CAS extension does not include a mandatory jar.
Output from mvn dependency:tree
[INFO] ± org.springframework.security:spring-security-cas:jar:3.1.0.RELEASE:compile
[INFO] | ± org.jasig.cas.client:cas-client-core:jar:3.1.12:compile
The second one is missing. After installing the CAS extension GeoServer wont start and the log file does not give a reasonable hint (at least for me).
Workaround:
Download the attached file “cas-client-core-3.1.12.jar” and save it to the Geoserver WEB-INF/lib folder.
Project:
Priority:
MajorMajor
Reporter:
Christian Mueller
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
