[Geoserver-devel] [jira] (GEOS-5815) Can't find renamed default Styles
Jonathan Moules created BugGEOS-5815
Can’t find renamed default Styles
Issue Type:
BugBug
Affects Versions:
2.3.1
Assignee:
Andrea Aime
Created:
16/May/13 11:19 AM
Description:
I’ve renamed my default styles using GeoServer’s styles page (they were: line, point, polygon, raster).
Before renaming, Geoserver would automatically choose a default style for any new layer from one of these. But now it’s blank.
Normally, if I rename a style, the layers that use it keep working fine and automatically point to the new style (it uses an ID I think) - this function should probably do so to.
Project:
Priority:
MajorMajor
Reporter:
Jonathan Moules
This message is automatically generated by JIRA. If you think it was sent incorrectly, please contact your JIRA administrators For more information on JIRA, see: [http://www.atlassian.com/software/jira](http://www.atlassian.com/software/jira)
